Need some input on spraying 150 shot.......
I will be adding a nitrous system very soon and I'm set on getting 150hp system. I've been contemplating the Nitrous Direct LS1/LS6 single stage plate system (wet system). I will buy a progressive controller with built in window switch and the FPSS to be safe.
Now here is where I need some input! What am I forgetting about? Will this system be okay with my stock fuel system? I need to keep this system from blowing my motor (basically as safe as I can without compromising HP) and I'm kinda worried about my high CR.
ANY AND ALL INPUTS WELCOME..........THANKS!
And Robert56 was talking to me about a Kenne Belle boosta pump with will give me up to 50% more fuel pressure.
I really want a safe setup, but dread having to replace my fuel pump. It such a pain in the *** to get too.
Dont shortcut now upgrade the pump.
Good luck
Roy
On the bap boosting fuel pressure would be for a dry hit (a tuning aid), and staying about 60psi for a wet hit, and will remain at 60psi under load. If you boost pressure with a wet hit it'll really go rich, and your allready adding fuel through the wet jet.
Robert
Not wanting 8 more melted plugs... I was looking at piece mealing it together, but if there is a kit available from a sponsor I'm all for it. http://forums.corvetteforum.com/showthread.php?t=739059
http://www.pfyc.com/store/merchant.m...y_Code=VTUNDER
http://photos.strasser.us/gallery2/m...g2_itemId=7882
http://forums.corvetteforum.com/show...49&forum_id=86
Robert
Robert
How hard is it to upgrade my fuel pump? And what exactly needs to be done to swap it out?
I was under the impression that I needed to get into the fuel tanks to swap it out and since the Vette has 2 tanks and a pump to keep the tanks equal that it would be a huge PITA!!
Roy
I would really appreciate it if you told me what happened so i can do my best to avoid it.
Thanks for the post.
Robert
