need help quick, i can't get my window switch to work
So i go buy an MSD window switch, i found a few different ways to wire these things up on here so i tried another way AGAIN it would not work. And again it would work if i put a jumper in place of the on RPM pill. It's like it's not seeing the tach signal and i have the wire running to PIN 10 on the PCM. I cut that #10 wire just to see what would happen and the car started and all the gauges worked the only thing that didn't work was the TCS light came on is that right? If it's a tach signal shouldn't it affect the tach in the car?
Can someone throw me some help please i dunno what else to do, also i have an early 99 so i thought maybe the tach signal wire was where the 98's were......Nope there's no wire in pin 35 at all
No i got the right wire it says 10 on it i know it's the right one
Here just to prove i have the right wire
And that's how i have the system wired before anyone says i have it wired wrong too
. That and the yellow wire from the window switch can only handle 1.5amp's apparently the FPSS puts out more then that and by some luck i bypassed it .
plz tell how u bypassed the yellow. i spent an entire day trying to get the tack signal to work. even pulled the relay off and wired everything direct. no go.
then stole the window switch of my daughter car thinking mine was shot...still no go...
Here's a diagram of how i wired mine since it wouldn't work the window switch connected directly to the FPSS.
old image but I think you get the idea.
Ricky
