1 gallon fuel cell
Old 04-09-2006, 05:54 AM
anarchy99's Avatar
Coolant recovery tank... I need to get another tank for my pcv. I think I'm just going to make one out of pipe.
Old 04-09-2006, 06:05 AM
chpmnsws6's Avatar
I was wondoring which brand it was though. Was thinking about the summit plastic but that one looks great
Old 04-09-2006, 06:09 AM
anarchy99's Avatar
I think it's the summit one... That got thrown into the deal with the battery box for 10.00. I think I remember him saying it was from summit... Or it might have been a be cool one.
Old 04-09-2006, 06:15 AM
chpmnsws6's Avatar
holy hell of a deal!
thread jacked... Hit me up on AIM sometime so we don't kill this poor mans thread :p
Old 04-09-2006, 06:21 AM
anarchy99's Avatar
Will do...I don't think he'll mind too much about the hijack though since it's got mostly pictures relating to his topic... Might give some ideas anyways. I'll hit you up sometime and post up a video of the car here in a couple weeks hopefully...
Old 04-09-2006, 07:43 AM
7 Second Club
ty_ty13's Avatar
Originally Posted by anarchy99
hey chpmnsws6, got pics of that fuel cell mounted? I have the 1 gallon jaz fuel cell also and I was wondering if you had to do all the same stuff I had to do to get it mounted... I.E. Sawzaw!!!
thats exactically what i did except on the other side... i moved the battery to the back.
Old 04-09-2006, 08:07 AM
anarchy99's Avatar
You got any pics? I'd like to see how you did it.
Old 04-09-2006, 03:50 PM
pigpen's Avatar
No problem on the hijack , but back on subject, here's where I'll be mouting it (cut-out area):
Not quite the standard 4th gen location though. With the shorter cell I listed on page 1, I should have plenty of room to mount the pump and filter under the tank, then the put the regulator on the firewall.
I think I'm going to go ahead and get the 6 x 6 x 6 and see how it looks. If all goes well, I'll get a 2nd one for the other side for the alky injection tank.
Thanks again for the replys.
Old 04-09-2006, 07:57 PM
anarchy99's Avatar
must be nice to have sooooo much room... I'm still looking for spots to hide more ****. I've even got stuff hidden in both wheel wells!!!!
Old 04-09-2006, 11:52 PM
Gary Z's Avatar
Originally Posted by pigpen
Thanks guys - that sounds good. The only other thing I'm worried about, is whether the tank I have listed is actually 1 gallon - Summit lists it as 1 gal, but it's only 6x6x6. All the plastic 1 gall cells show to be 6x6x12.
One US gallon = 231 cubic inches. 6^3 = 216.
Old 04-10-2006, 12:06 AM
pigpen's Avatar
Thanks for the figures, that looks close enough to work then, and still get at least 2 passes before refilling.
I think that the posted Summit measurements are estimation though, and the actual cell will be slightly larger. I've got an opaque jazz 1 gallon cell that I was originally planning on using for the alky injection. It's advertised as 6 x 6 x12, but it's less than 6" around the strapps/brackets, and is not quite 11 inches deep. Also comparing the top of my Jazz cell against the top of the alum cell in the pic, it looks like the alum cell is a bit wider (based on the distance from the cap area to the edge of the cell - and assuming the caps are the same size)
Old 04-10-2006, 12:13 AM
  #32
pigpen's Avatar
Definelty nice to have the room under the hood and the room to work - that was a major deciding factor, when I bought the 68 and parted the 93
I ran a two stage 150/150 setup in the 93 with one stage hidden (only advertised a 100 shot. The 68 is tubbed, cagged, and has a tilt glass front end - not a sleeper in any way, so I'm not really bothering to hide anything this time.
Old 04-10-2006, 09:39 PM
  #33
DeltaT's Avatar
Since you're running a seperate fuel system for the nitrous, have you considered using methanol or 50/50 methanol gas as a fuel?
I'm planning to try the 50/50, because it's less corrosive and doesn't need to be flushed as often. E85 is an option, but you can't get it in Cal.
Jim
Old 04-11-2006, 07:53 PM
  #34
pigpen's Avatar
I havent really thought about it. I'm going to see how it works with race gas first. If that does OK - then I'll probably leave it alone.
Quick Reply: 1 gallon fuel cell
