cam choice?
Old Apr 8, 2006 | 11:56 PM
phoenix's Avatar
Default cam choice?
i am planing on building a LS2 402 12.5:1 CR motor. i want to spray a 300-400 shot. what is the best cam for something like this. i want something that is going to give me good N/A power and great nitrous power.
thnaks
~mike
Old Apr 9, 2006 | 12:04 AM
CAT3's Avatar
Restricted User
Mike, unfortunately I dont think too many ppl on here are qualified to answer that question. Whats best for you and them are different, and the mods, and what your end goals are will effect the grind. Have you contacted Comp Cams, Futral, or other cam grinders for help? I personally would find someone like Ed Curtis, EDC on here, that requests you to fill out a very in-depth cam request sheet, so the grinder can have ALL available data to make the best possible grind with. Just saying a 12.5 402 is not enough. gears, tires, trans, weight, intake, exhaust, and so much more go into this.
By comparison, I have a 347 11.6:1 compression, A3 4k stall, 3.50 geared 9", probably around 3350lbs not sure, 1 7/8" headers, and catback...for a 300 shot, Ed ground my cam to be 231/242 .637"/.622" 114*lsa with planned AFR 225 heads. Now I went with ETP 11* heads in a 225cc runner, now I could get away with even more cam with the 11* valve arrangements...oh well. No, I havent made a full pass on anything over 130+/- shot yet.
Good luck.
Old Apr 9, 2006 | 01:18 PM
phoenix's Avatar
hey thanks for the good info, i thought that is what i was going to have to do. i was hoping someone had a set up like this. so why havent you uped the shot yet?
