Troubleshooting!
Old Apr 12, 2006 | 07:51 PM
HowellSoccer88's Avatar
Default Troubleshooting!
Alright well Im stuck. I got my car done like 2 weeks ago (HSW dry kit) and it went pretty smooth. Now I am helping a buddy (running a dry HSW dry kit as well) and heres the situation:
All the wires are run
Purge works great
The activation switch for the N2O powers on
I made a circuit with the WOT switch and when you click it on it completes like its supposed to
My relay is working to the best of my knowledge. Tested with light and it lights up for power.
If you ground the N2O noid and hook it to direct power it sprays
The problem is when you turn the activation switch on and the WOT switch is activated nothing happens. The pins and wires are hooked up correctly. I also bought a new relay and that didnt help either. I dont really know where to go from here. If anyone could gimme some input thatd be great!
Old Apr 12, 2006 | 07:54 PM
brad8266's Avatar
Could be that the wot switch is not hooked up to the activation switch properly. Should be a series connection. Do you have a window switch in the circuit??
Old Apr 12, 2006 | 07:58 PM
Not running a window switch. It goes wire from activation switch >to WOT > from WOT > to relay > relay is powered and grounded and the other wire is going to the solenoid
Old Apr 12, 2006 | 08:04 PM
Matt@HSW's Avatar
Double check the connections on the wot switch.
Matt
Old Apr 12, 2006 | 08:07 PM
brad8266's Avatar
yeah make sure the butterfly is pushing the switch all the way down.
Old Apr 12, 2006 | 08:08 PM
Im pretty sure its hooked up right but again I will keep checking. If anyone has any other ideas please post up!
Old Apr 12, 2006 | 08:09 PM
Well even when you just push the switch by hand its not spraying
Old Apr 12, 2006 | 09:04 PM
iamsickofitall's Avatar
i'd say to check your grounds again
Old Apr 12, 2006 | 09:16 PM
Matt@HSW's Avatar
Make sure the wires are on the right posts & make sure the crimped connections are good too.
Matt
