Wiring Help..
Old Apr 13, 2006 | 06:42 AM
BADFNTA's Avatar
Restricted User
Default Wiring Help..
Hey guys, This is what I have come up with and I just wanted to make sure everything is correct..
Here is what i have-
NX Throttle Position Sensor Activation Switch
NX Relay
MSD RPM Activated window Switch
Here is the wiring i came up with-
TPSAS-
Pink--->Red on Relay
Red--->ACC Switch
Black--->Ground
White--->Blue Wire on TPS
Relay-
Black--->12 Volt
Green--->Solenoids
Red--->Pink on TPSAS
White--->Yellow on MSD
MSD-
Red--->ACC Switch
Yellow--->White on Relay
Black--->Ground
White--->Pin 10 on PCM
Please tell me if this sounds right or if any changes should be made..
