Tach wire for MSD Window Switch?
Old Apr 13, 2006 | 08:09 PM
BADFNTA's Avatar
Restricted User
Default Tach wire for MSD Window Switch?
I thought this would be a simple question but I still can't figure it out. I have read that it was Pin #10 but when i pull out my PCM what do you know I have NO Pin #10 Wire. Somebody Please Help!
Old Apr 13, 2006 | 08:12 PM
brad8266's Avatar
Its a white wire(#10) that comes out from the PCM, you do not have to pull the PCM to get to it. If you look at the PCM while its installed where the wires all come out you can read the wire numbers.
Old Apr 13, 2006 | 09:12 PM
02WS6LS1's Avatar
IT IS PIN 35 ON 98 CARS AND IT IS PIN 10 ON 99 AND UP HERE IS A CHART TO CHECK OUT.www.ls2.com/boggs/torques/enginetorques.htm IT HAS EVER THING YOU NEED. THEN GO TO 98 PCM PIN ASSIGNMENTS.
Old Apr 13, 2006 | 09:16 PM
brad8266's Avatar
Sorry about that didnt even notice you had a 98, the bastard stepchild of LSx engines.
Old Apr 14, 2006 | 09:03 AM
BADFNTA's Avatar
Restricted User
Thanks Alot Guys this should be the Final step before I'm sprayin my brains out..
Old Apr 14, 2006 | 06:39 PM
vette-dream's Avatar
Is there a site with some photos showing pin 35 (98 C5 LS1). I've got my battery tray out now and can see lots of 'dirty' black wires, but no blue/red circuits. Do I need to pull out the computer from down below the battery?
Old Apr 14, 2006 | 08:08 PM
It does for the red plug, but it's the blue one that you want.. It should show up as the Tach wire.
Does anyone have a picture of how to get 'to' pin 35 on a C5?
Old Apr 14, 2006 | 11:10 PM
Ramshaft's Avatar
where is the pcm on a 99 ta i know that it is white wire 10 but don't know exactly where the pcm is.
Old Apr 18, 2006 | 07:08 AM
BADFNTA's Avatar
Restricted User
Passenger side under the hood up near your Wiper Cowl
Old Apr 18, 2006 | 07:31 AM
Ramshaft's Avatar
thanks
Old Apr 18, 2006 | 09:38 AM
NXJeremy's Avatar
You could also take the easy way out and just connect the window switch to the negative side of any one of the coil packs.
Old Apr 26, 2006 | 12:21 PM
z28hottie's Avatar
how about on a 96 z? what pin is it then?
