ran worse after nitrous at the track
Originally Posted by matrik
...Also, I'm stilling running tr-55's instead of colder tr-6's....
when you pulled the lines off to see it spray, which side of the solenoid did you take off? the solenoid itself could be clogged or not working 100% correctly. you just have to work your way from the bottle up to the plate where it sprays, and test everything you can think of.
Originally Posted by white2001s10
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Try 39 nitrous and 22 fuel next time.
![Werd](https://ls1tech.com/forums/images/smilies2/werd.gif)
Originally Posted by 396D1SS
tr-55's are not that bad with a 100 shot ive sprayed alot of 200shot runs and they are still ok
I'd go back and recheck those jets one more time. Make sure the smaller jet is on the fuel side.
