TRex / big shot, progressive ramp..
Old Apr 16, 2006 | 10:00 PM
Hocky's Avatar
Default TRex / big shot, progressive ramp..
In an effort to keep the stock bottom end together for a bit (yes, I know it will break soon enough, I don't care), I am using the fjo controller on the bigger hits. The car is a bolt on, trex set up and I am looking at fairly commonly a 150 hit and occassionally a 200 hit. I probably don't really need the progressive on the 150 as long as I start the spray a bit late, but in any case how quickly would everyone recommend ramping (via rpm) the nitrous for the 150 and 200 hit? Start at 3000 and full spray by 5500ish?
Old Apr 17, 2006 | 10:11 AM
Nitro Dave's Nitrous Outlet's Avatar
The sooner you can ramp it up the better times you will run. 3/4 of the race is in the 60 foot. If you can hit a 100 percent out of the hole even better.
Dave
Old Apr 17, 2006 | 11:01 AM
Hocky's Avatar
Dave
No argument, but the stock bottom end is the iffy part on that.
Old Apr 17, 2006 | 11:05 AM
red90cobra's Avatar
dude 150 shouldn't be a problem can you hook out of the hole with a 150 shot? do you have a built rear end?
Old Apr 17, 2006 | 11:30 AM
Hocky's Avatar
I won't hook the whole way down the track.... I don't have an fbody. heh
Old Apr 18, 2006 | 12:01 AM
ablakez28's Avatar
i ran my t-rex with a 150 shot for two seasons now and about to start my third and i spray as soon as i can out the hole.
Old Apr 18, 2006 | 09:49 AM
Phil99vette's Avatar
7 Second Club
I am planning setting the nitrous up so it comes on in 2nd gear. My car will only go so fast @ the 60' mark so more nitrous only beats on the parts. My goal is to use as little nitrous as possible to get 1.38-1.42 60'.
