Simple Ramcharger Question
Old Apr 17, 2006 | 10:27 AM
MetallicaMatt's Avatar
Default Simple Ramcharger Question
hey guys,
i'm swapping out my clutch, so i figured with the Tranny out of the way, NOW would be a good time to connect my Ramcharger timing tuner.
My question is, where does it plug into the crank sensor? I'm underneath the car, looking up, but i'm not sure which sensor i'm supposed to plug into
does anybody have a pic?
There are 2 plugs on the back of the block, basically 12 o'clock from the clutch
just wondering which one to plug into
thanks!
Old Apr 17, 2006 | 11:20 AM
Matt@HSW's Avatar
It's on top of the starter on the pass side. You might have to drop the starter down to get to it.
Matt
Originally Posted by MetallicaMatt
hey guys,
thanks!
Old Apr 17, 2006 | 11:44 AM
thanks matt
do you happen to have a pic? i just want to make sure i'm in the right neighborhood
Old Apr 17, 2006 | 02:56 PM
Matt@HSW's Avatar
I don't, but it's the only plug up there with 4 contacts on it. You should see it as soon as the starter is out of the way.
Matt
Old Apr 18, 2006 | 11:19 PM
AgFormula02's Avatar
Drop the starter. (Disconect battery first) You can't miss it.
BTW: Careful on the rounting, you are going to be really close to the header.
Old Apr 19, 2006 | 04:10 PM
dropping the starter is a 'must'?
pain in the @$$?
Old Apr 19, 2006 | 04:53 PM
Matt@HSW's Avatar
Unless you have real small hands I say yes. Two bolts to take it out, pretty easy.
Matt
pain in the @$$?
