Nitrous Problem
Old Apr 19, 2006 | 09:05 PM
01juicedc5's Avatar
Default Nitrous Problem
I have a 2001 corvette that I have installd nitrous. The problem I am having is that when I turn my activation switch to the ON position the nitrous goes through the solinoid straight into the intake. When I turn the switch off it stops. I disconnected the nitrous and did a dry test on the noids and when i turn on and off the switch the noids do click. Any suggestions. Thanks
Old Apr 19, 2006 | 09:10 PM
oange ss's Avatar
you have your switch wired straight to the noids....use a WOT switch and window switch at a minimum
Old Apr 19, 2006 | 09:12 PM
01juicedc5's Avatar
i have a wot switch and a window switch
Old Apr 19, 2006 | 09:14 PM
01juicedc5's Avatar
im thinking i either have a noid that is hung open....even though it is new, or i have a wiring problem somewhere
Old Apr 19, 2006 | 10:04 PM
Nitro Dave's Nitrous Outlet's Avatar
What window switch are you using? Something is wired wrong or programed wrong.
Dave
Old Apr 19, 2006 | 10:19 PM
NitrousDirect's Avatar
humm never heard of that actually who's setup do you have?? We'll try to help you
Old Apr 19, 2006 | 10:35 PM
Robert56's Avatar
Dosen't sound like a stuck noid cause the nitrous only flows when you hit master arm switch, correct. Somewhere, you got something crossed up and have power going directly to noid upon activation of the arm sw. Recheck your wiring.
Robert
Old Apr 19, 2006 | 10:40 PM
Red Heartbeat's Avatar
You would not happen to have installed an NX IceMan Nitrous solenoid, would you? The nitrous outlet is on the bottom of the solenoid. The outlet directly across from the inlet is for a purge solenoid on the IceMan noids.
Old Apr 19, 2006 | 11:12 PM
Spenser309's Avatar
juiced make a wiring diagram and post it so we can see whats supposedly happening according to you.
