WOT switch mounting
Old Apr 21, 2006 | 02:13 PM
99FormulaM6's Avatar
Default WOT switch mounting
how the hell do i do it? i have a TNT F1 kit, and i cant for the life of me figure it out
Old Apr 21, 2006 | 02:17 PM
Nitro Dave's Nitrous Outlet's Avatar
I do not have a universal bracket picture handy. But you will need to twist the bracket to fit your needs. It works you just have to be creative. If all else fails we do have a machines bracket out a billit alluminum that just bolts on.
http://www.nitrousoutlet.com/catalog...product_id=821
Dave
Old Apr 21, 2006 | 02:29 PM
i knew id have to twist it....but what bolts do i mount it to first?
Old Apr 21, 2006 | 02:39 PM
It has been so long since I used one of the ones that come in the kit I can not remember. Maybe someone else will post up with some insite. Sorry.
Dave
Old Apr 21, 2006 | 02:42 PM
keliente's Avatar
I installed mine and I hated the way it looked. The rest of my kit was hidden and then there was this silly WOT switch just hanging in the open.
I got one of the electronic wide open throttle sensors from Harris Speed Works, I love it. It was easy to install and you can put it wherever you want.
Old Apr 21, 2006 | 04:13 PM
NaughtyIROC's Avatar
I'm still not sure why these universal brackets are being used when they are so unsightly. It just seems if you put so much time into your engine and mods and making things look nice and neat then you'd want a nice WOT switch that just bolts right up - to finish off the hard work.
Old Apr 21, 2006 | 06:52 PM
Ramshaft's Avatar
i just put my temp one in so i can go to the track i ordered the custom bracket from nitrous outlet. it is not the prettiest thing but hey it will work for tonight. i had to bend the bracket and also the tip of the WOT switch. but make sure the bend is after it passes the little button that is under the activation lever. hope this helps.
Old Apr 21, 2006 | 07:25 PM
muraoka's Avatar
i welded the bracket to a 2" muffler clamp. then mounted it on the steering column. its hidden under the dash.
Old Apr 21, 2006 | 08:33 PM
Robert56's Avatar
Here's the cleanest way to do it, under the pedal. It's a vette, but you get the idea.
Robert
