NOS Wet Plate System Installed
Old Apr 25, 2006 | 08:33 PM
Technoman64's Avatar
Default NOS Wet Plate System Installed
I ran the NOS Wet Plate system for the first time today. Worked excellant as far as I can tell from seat of the pants
The install was straight forward and I also installed a FPSS and a Purge Solenoid to the system. The throttle switch bracket required just a slight tweaking. I removed just a bit of material with a grinder for clearance. Other than that it was just a bolt on installation.
I also included a controller and set it up for 40% Start to 100% in 1 second for each gear. Seemed just a tad rich at the start of each gear. I will get the Wideband Commander installed before the next run to verify this before any jet change. I did not pull any timing as I was only running the 100hp(smallest) jets that came with the kit.
All in all I am very pleased with the kit and the ease of install. Now I need to verify the Air-Fuel and head for the local track for some fun and testing.
Bigger jets, hmmm
Old Apr 25, 2006 | 09:44 PM
CAT3's Avatar
Restricted User
No pics, WTF? Come one man, you cant tease like this
Old Apr 26, 2006 | 05:39 AM
I will post some tonight. The controller is a proto-type and I am not a sponsor so that will not be shown.
I do not have experiance with 2-steps and cats. I have read that you should not use a 2-step with cats installed. Do they fill with fuel and get to hot from burning off the excess? If the 2-step always alternated the firing of the cylinders would this help to burn off excess fuel?
I just need to test with a wideband. I realize my car is not really in need of this feature. I may just buy some slicks and a new clutch though and get a tad more serious. I have spent many years working with motorcycles and R&D. I must admit that having 4 wheels is quite fun also.
Also if a person were to take the analog output from a wideband controller and use it to shut off the nitrous in case of going lean where would be the best place to put the sensor?
Old Apr 26, 2006 | 10:43 AM
CAT3's Avatar
Restricted User
2Steps and cats = not happyt together, yes fuel in the catalyst causes bad things.
I prefer to mount the wideband as far upstream in the collector as possible, just keeping it in the flow of all four cylinders on that bank. I had my last one setup in front of the stock NB's, but currently on the Kooks I have it about 2" post NB.
