Anyone mounted a 5lb here?
Old Apr 26, 2006 | 02:36 PM
FL01SS's Avatar
Default Anyone mounted a 5lb here?
I searched and came up with nothing. Has anyone mounted a 5 lb bottle in here?
I was thinking of making a false enclosure with grill and all and mounting a 5lb bottle there. I took some quick measurements, and it should fit. Curious if anyone had any pics if they had done it.
Old Apr 27, 2006 | 07:53 AM
98_Formula's Avatar
'im sure u could, i think alot of people put the bottle in there spare tire area
Old Apr 27, 2006 | 09:27 AM
TNTramair's Avatar
im sure he knows but i beleive his intention is too deceive the unsuspecting rival... id mount the 5lb bottle under the front headlamp/front bumper area.... less lines to run.
Old Apr 27, 2006 | 12:44 PM
FL01SS's Avatar
I don't think it would be possible to conceal it there though.
Old Apr 27, 2006 | 02:26 PM
TNTramair's Avatar
HMM...maybe your right on a camaro...but on a t/a you cant see it unless the headlamp is up. goodluck though.
Old Apr 27, 2006 | 03:12 PM
daryl2cb@yahoo.com's Avatar
you could also place it where the air pump is, or was in a z, should definatley fit underthere, and if the bottle is black, it should be well hidden. Mine is in the spare tire well.
Old Apr 27, 2006 | 06:24 PM
FL01SS's Avatar
^^^ You think a 5 lb bottle would realy fit there? Is that common? I know most people have a 10 in the spare tire well or on the hump in the back seat. I just thought it would be a good place to conceal it behind a fake speaker enclosure.
Old Apr 27, 2006 | 06:30 PM
V8pwrdz28's Avatar
i like that idea, may have to steal it lol
Old Apr 28, 2006 | 03:22 AM
Somebody09's Avatar
Yes, that is where I hid my bottle. Yes, I hid it behind a fake speaker. It's ok, but it's only 5lbs of nitrous. I have pics without the speaker... I'll see if I can remote into my PC at home.
Old May 1, 2006 | 07:44 AM
FL01SS's Avatar
I'd like to see the pics! Also, how big of a shot are you running, and how many do you get out of that 5 lb bottle??
Old May 1, 2006 | 12:47 PM
Reject's Avatar
wow didnt expect a place like that.....we've all been given the heads up now!
Old May 1, 2006 | 07:04 PM
Somebody09's Avatar
Honestly I can't find my pics... I'll take some now.
edit: Right now, no brackets hold the bottle in place... only the tight, tight fit. If I don't get the angle on the bottle opener just right, it pushes up on the plastic panel a bit. I've never had it fall out on me, though I've never tried Auto-Xing with it either. The bottle heater is the one NX sells for 10 and 15lb bottles, but the straps were shortened a little. The heater doesn't touch anything except the bottle. I haven't installed the blow-down tube yet(probably going to be a -8AN hose), but that shouldn't be a problem. I also had to ditch the 16' line from NX and get 20' from NOS... Hey, it was $50 cheaper!
I'm planning on running a 75-125 dry shot on this. It'll be a supplement to my 300 direct port, or in some cases, a cheater shot. I haven't done the dry yet; however, it used to feed my 175 wet shot on the Maximizer (44% on at 2750/3000 rpm progressing to 88% at 3500 rpm, shut down at 5900 rpm using 200 jets: NX's 76n & 44f I think) I probably got about 4-5 good runs out of it plus a quick purge for every run with the bottle at 1000+ psi each, except sometimes run #5 would have 900 and die hard on me. All runs were on the street. At the track I normally tempted fate with 200 and 250 shots.
Old May 2, 2006 | 10:10 AM
FL01SS's Avatar
Thanks for the pics! I didn't think I could get a 10lb bottle in there!
Old May 10, 2006 | 12:43 PM
6speeder's Avatar
You should mount it behind the plastic panel behind the left rear tire. I was going to mount mine there then I went direct port and stopped caring about hiding it. Good luck
Old May 10, 2006 | 02:54 PM
Somebody09's Avatar
What plastic panel? I wasn't aware of any plastic around our rear tires.
Old May 10, 2006 | 03:38 PM
6speeder's Avatar
it's the area directly behind the fuel fill nozzle.
Old May 10, 2006 | 09:26 PM
Somebody09's Avatar
Good luck getting a 5lber in there. 2.5lbs is more realistic however.
Old May 11, 2006 | 06:54 AM
6speeder's Avatar
It'll fit, I just never fabbed up brackets to mount it behind there.
