View Poll Results: Spray 100 shot?
Yes
92.31%
No
7.69%
Voters: 156. You may not vote on this poll
Spraying 100 shot on 110k engine?
Old Apr 27, 2006 | 10:31 AM
777's Avatar
777
Default Spraying 100 shot on 110k engine?
I've got a 110k mile engine with cam and bolt ons. Makes right around 385rwhp and 370rwtq. I'm trying to debate on whether to buy a kit and spray 100 shot. I really want this engine to last awhile and the power isn't really necassary as I don't race it often. I just am wondering the effects it will take on my engine over time. Will I need new injectors? I know I need to get a new fuel pump as mine is about to go i think. I need to do a compression test to see where the engine stands, but I'm just wondering how much this will affect the life of my engine being as it has fairly high mileage.
Old Apr 27, 2006 | 10:54 AM
fauslpss's Avatar
A friend of mine has a stock 97' LT1 and is shoting a 150 and his car is in the 120-130k mile range.
Old Apr 27, 2006 | 11:08 AM
whiteLS1's Avatar
as long as you have a good tune. you will be fine. especally since you say you dont race much
Old Apr 27, 2006 | 03:00 PM
OffspringZ28's Avatar
all day. itll clean the carbon out of the intake manifold (seriously)
Old Apr 27, 2006 | 03:06 PM
daryl2cb@yahoo.com's Avatar
LOL, I think all of us no2 junkies are going to say yes, I even voted yes, what better way to get that 408!!
Old Apr 27, 2006 | 04:26 PM
ohsofast's Avatar
My car has almost 95,000 miles and my car is good
Old Apr 27, 2006 | 04:28 PM
Zach@Texas-Speed's Avatar
My TA has 121k miles and I spray a 100-150 shot on it regularly....its got stock 28lb injectors and a walbro. She knows her role!!
Old Apr 27, 2006 | 05:55 PM
777's Avatar
777
Well that's what I needed to hear since that's how it would be with mine. 28lbr's and a walbro. We'll see how things pan out. I'm not quite sure if I want to spend 500 for the nitrous and pump and all accesorries.
Old Apr 27, 2006 | 08:05 PM
BAD FNZ's Avatar
Friend has a 99 SS spraying a 175 shot on a 105k motor, and another friend has a 96 TA with a 150 shot on a 120k motor..
Old Apr 27, 2006 | 08:52 PM
CAT3's Avatar
Restricted User
Wet kit doesnt bother injectors at all. As long as your tune it good, and you got the fuel pump (since you think yours is dying), new plugs etc, you should be fine. Not sure on cleaning the carbon out of the intake, but it will blow the **** off the tops of the pistons, that much I can say with confidence. GL
Charlie
Old Apr 27, 2006 | 10:57 PM
dirt track racer 81's Avatar
ive put over 50 bottles thru a 121,xxx mile truck...no problems on the motor part
Old Apr 28, 2006 | 08:29 AM
777's Avatar
777
Can you please remove that link in your sig, it's against site policy.
Old Apr 28, 2006 | 10:46 AM
I've had a wet setup w/ a second stage dry, probably sent 15-20 bottle through the motor since 90k miles. The 28lb'ers held fuel up to about 520rwhp before too much duty-cycle on the dry shot. I'll have to look at what timing and A/F are. As long as you dont spin it too high, put enough fuel to it and back off some timing it should hold together for a long while. I've looked at bearings and they seem to be fine. Its all about tuning and getting lucky with the rod bolts
Old Apr 28, 2006 | 12:01 PM
777's Avatar
777
I don't spin past 6,000rpms usually. Maybe once a month I'll hit 6500 once, if that.
Old Apr 28, 2006 | 01:48 PM
1fastz28nx's Avatar
I spray 150 shot at 150,000 miles. DO IT!!!!
Old Apr 28, 2006 | 07:35 PM
Nice!!
Old Apr 28, 2006 | 07:48 PM
burnzilla's Avatar
Very True, and ive heard many others stories like "dirt tracks".
Its not the mileage on the motor, but the condition of the internal parts.
Just because a car has 40K miles, doesnt mean its tougher than a 100K car.
Old Apr 28, 2006 | 07:51 PM
bad6as's Avatar
im gonna spray100-125 on 90k
Old Apr 28, 2006 | 07:54 PM
stangkiller2005's Avatar
id do it bro.. im also lookin to get a wet kit.. im just trying to learn as much as i can so i dont blow da motor aswell... so far ive picked up i need a fuel pump,retard timing,colder plugs,window switch,and shark nossel... am i missin anything???
Old Apr 29, 2006 | 04:52 AM
01Z28M6's Avatar
no2 junkies?
