polish my own bottle?
Old Apr 29, 2006 | 11:25 PM
aNuBiS's Avatar
Default polish my own bottle?
I have a 10lb blue NOS bottle. I however have a nitrous express MAF plate so was considering self polishing it with some sand paper. Has anyone here ever polished their own bottles from blue NOS bottles? Pics would be nice!
Old Apr 29, 2006 | 11:49 PM
chris.shea's Avatar
strip it, sand it and hit it with a polishing wheel. you should hit it with a coat of clear once you polished it to prevent oxidization of the aluminium.
Old Apr 30, 2006 | 12:16 AM
Reject's Avatar
that would look so bad ***!
Old Apr 30, 2006 | 12:24 AM
aNuBiS's Avatar
alright, i will most likely do this and I'll take pictures and post it up. Thanks
Old Apr 30, 2006 | 01:04 AM
chris.shea's Avatar
if its the anodized blue one the work will be quick and easy. you may even be able to start with 1500 grit to remove the blue and step up to 2000 and then use a wheel and polish. if its painted you will need to strip it and then follow the steps above. if the bottles are rough under the paint you will need to sand it smooth starting with 3xx grit and moving up.
Old Apr 30, 2006 | 06:06 AM
BigDaddyZ28's Avatar
If it is painted then aircraft grade paint stripper (@$10 to $15 a gal) will get the paint gone FAST. I would not recommend leaving it on the aluminum any longer than you have to to get the paint loose. A few minutes should do it depending on the quality of the paint used.
If it were me, I would then follow with 320grit, 600, 900 to 1000, then some wet sanding with the 1000 followed by hitting it with some 3M Hand Glaze (awesome stuff) before the final polishing/buffing.
Aluminum is very easy to polish and it should look awesome when you get it done. Keep us updated with some pics as you go.
Best of luck with your project aNuBiS.
Old Apr 30, 2006 | 01:53 PM
aNuBiS's Avatar
One more question before I get started on this. Do I need to keep the sticker or label on the bottle? Or can I remove all that too.
Old Apr 30, 2006 | 02:51 PM
chris.shea's Avatar
i think your supposed to keep a sticker that shows the contents of the bottle. if you peel it off just get another from whoever you want(nos, nx, zex....) they sell them with thier conversion kits im sure you can pik up just a bottle sticker.
Old Apr 30, 2006 | 04:05 PM
stevethepirate's Avatar
i prefer having someone else polish my bottle, but that might just be me....
yeah, technically you need the sticker to show the contents, but i doubt its a big deal.
post pics if you do decide to polish it!
