air/fuel on n20
Old 05-07-2006, 12:25 AM
soonerbob's Avatar
Default air/fuel on n20
Anyone know what a good air/fuel ratio on a ls1 with a 100 shot wet system is.
Old 05-07-2006, 12:38 PM
Robert56's Avatar
11.7 area, or slightly leaner for a hit that size.
Robert
Old 05-07-2006, 12:45 PM
brad8266's Avatar
I am from mid 12 at the lower rpm to low 11 at the high end. Havent detected knock yet.
You definetely want to be below 12.5 although I ran untuned for a while running like 14.0 on the spray, I cant believe it didnt even knock then. I must have been lucky. At least if you are low 12's you will have the peace of mind knowing you wont lean out.
