FJO install question!
John
I'm under the impression that the FJO unit itself is one circuit and the driver portion that controls the noids is what ultimately is on or off based on your criteria to turn-on the solonoids.
John
Once the box trigger critiera are met then the noids can find ground and you will have a higher amp draw. MAX run time is 20 seconds.
Hope this helps
Ricky
tim
tim
We'll get it straighten out for you.
Ricky
