Like the guage instal??(a/c vent)
Old May 14, 2006 | 10:31 PM
TA4EVR's Avatar
Default Like the guage instal??(a/c vent)
I installed my switches and a pressure guage in my ac vent.
[IMG][/IMG]
[IMG][/IMG]
Old May 14, 2006 | 10:53 PM
nickdotcom's Avatar
www.imageshack.us
Old May 15, 2006 | 10:29 PM
TA4EVR's Avatar
guess not huh
Old May 15, 2006 | 10:44 PM
BlackBirdWs6Zzz's Avatar
looks good. Looks clean still. A+
Old May 16, 2006 | 12:30 AM
rmitchell242's Avatar
I was looking throught the back window of a TA yesterday and that is the first thing I thought of when i saw the 3 vents all lined up!
Looks nice man
Old May 16, 2006 | 06:13 PM
TA4EVR's Avatar
Thanks guys. It was suprisingly ALOT easier then I would have thought. Plus, my other vent blow stronger now!
Old May 16, 2006 | 06:15 PM
krazy4's Avatar
looks pretty sweet
Old May 17, 2006 | 08:36 AM
goodrich969's Avatar
how did you do it.. i want to mount my guage there
Old May 17, 2006 | 08:44 AM
brad8266's Avatar
Looks pretty good.
Old May 17, 2006 | 08:20 PM
TA4EVR's Avatar
It's pretty easy. Pull your radio out and stick your hand back behind the vents. There isn't anything at all there. Pop your vents out and get a drill bit and drill through the back of the a/c duct. Run your wires and such through the hole. If you need more detail let me know!!
Old May 17, 2006 | 08:41 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
Great job!
Dean
Old May 17, 2006 | 09:36 PM
TA4EVR's Avatar
Thanks alot Dean, you were a big help! Great service!
Old May 17, 2006 | 10:18 PM
flash12t's Avatar
what did u use around the gauge . . .?? how do u pop out the ac vent im thinkin bout doing this when i get my gauges. .
Old May 17, 2006 | 10:28 PM
TA4EVR's Avatar
Poping out the guages, after the first one, is easy. Put the fins going sides ways and then grab the middle brace (running up and down) with your fingers at the top and pull down a little bit, you can kinda see the clip back there, but take a screwdriver or something flat, stick in the little space you made by pulling it down and just pop out the outside cover. The vents are 2 different pieces, that gets the first piece out, the second piece you can see the clips on it, pop them out with a screwdriver as well.
Kind of funny what I used for the piece around the guages, I wanted a strong piece of black pastic, what I found, was a $1.50 thick black spatual (sp) from walmart, cut out a circle and it worked great! If anything is unclear let me know, I'll get a little more detailed! Thanks for looking!
Old Nov 8, 2007 | 02:28 PM
Tram's Avatar
Just curious if any of you guys doing this have had an obvious difference in the level a/c cooling?
I am thinking about doing this and putting one Interceptor in the far left vent or the vent on the drivers side and leaving the rest open..
However, I don't want to lose the a/c abilities..
Old Nov 8, 2007 | 03:51 PM
TA4EVR's Avatar
i actually liked mine better. it made the other vents blow harder
Old Nov 8, 2007 | 04:15 PM
Tram's Avatar
Yeh, that's kinda what I was thinkin...
Now, do I put it in the driver side, or one of the center vents..
Old Nov 8, 2007 | 04:20 PM
grn95t/a's Avatar
Old Nov 8, 2007 | 05:14 PM
DopeFedZ's Avatar
Damn the 2 1/16 gauges are definitely a hell of alot smaller than the 2 5/8. I have a 2 5/8 fuel pressure gauge in the driver vent. I guess I'll buy a 2 5/8 oil pressure gauge and a 2 1/16 wideband and rig it up to fit in the vents like you did.
Nice work!
