Change from BMN to Timing tuner?
Old May 16, 2006 | 11:15 PM
35thls1ss19's Avatar
Default Change from BMN to Timing tuner?
Hey guys, here es my delima. I just did H/C swap and i still want to spray 150 shot on top. I have the BMN window switch and love the way ir works! I never used the 1st gear lock out so i am not worried abotu that. But when i got my car tuned the tuner added soem timing. SO i was wonderin if i should get rid of the BMN and get the timin tuner? alot of you guys run this and will i be happy with it? Or should i just lose the extra hp drivng around and get a nitrious tune and keep the BMN? thanks for you input
Old May 17, 2006 | 01:59 AM
calongo_SS's Avatar
I just installed a timing tuner in my car and I like it so far. Easier to install than a WS, and works just as well.
Old May 17, 2006 | 07:42 AM
Matt@HSW's Avatar
If you don't mind losing the first gear lock out they can be real convenient. They do have a built in time delay feature that you could use if you ever need to.
Matt
Old May 17, 2006 | 12:04 PM
well last year i got a 9inch and i was uesing Mickey thompsons... i was hooking real good spray 100 shot out of the hole. So i figured 150 i should still do alrgiht
Old May 17, 2006 | 12:17 PM
TNTramair's Avatar
you'll love it. talk to Matt@hsw, he'll hook ya up
