sprayed the 200 shot lastnight
Old May 21, 2006 | 09:04 AM
348Beast's Avatar
Default sprayed the 200 shot lastnight
Ok so we got to the dyno for some "true street power" passes. The car had 325/50/15 M/T drag radials with 9#'s and the converter was unlocked.. We did 2 baseline pulls and first pull was 380/340 second was 387/342.. ok here comes the fun.. third pull on bottle (200 shot) it laid down 530/568 bottle ( i didn't check the bottle pressere and it was at 700psi.. So we turned the heater on and let it get up around 1080-1090psi.. So the forth pull was 572/617.. It made some crazy torque numbers.. i was happy.. mods are as followed.. stock block, crank, rods, diamond pistons, LS6 intake, 232/236 cam, 918 springs, manley 7.4 pushrods, stock rear gear 3.23, LT's.. and thats about it..
Old May 21, 2006 | 09:59 AM
2000Hawk's Avatar
Nice numbers, love that 600+ lbs of torque.
-Joel
Old May 21, 2006 | 10:57 AM
Robert56's Avatar
Nice, congrats. What kit?
Robert
Old May 21, 2006 | 11:05 AM
oner's Avatar
Damn 200 shot . I know guys do it all the time but, they got bigger ***** than me. Are any of your internals forged? What rings did you go with?
Old May 21, 2006 | 12:18 PM
CAT3's Avatar
Restricted User
oner, he is using forged pistons on stock rods. still pretty impressive.
I would try and keep the torque limited a little, using a progressive controller, or a staged setup helps. However, very nice output.
Old May 21, 2006 | 12:45 PM
LS144's Avatar
Had a buddy spraying 225 shot on his sotck block wit ha cam only! Put a stall in that car with some exhaust it was insane! It was like he had two times the gas pedal. He ran 6's in the 8th in that car.
Old May 21, 2006 | 02:14 PM
Reject's Avatar
freaky numbers for such little!
Old May 21, 2006 | 03:15 PM
blacktransam's Avatar
200 is alot of fun.. you should try 300 its a real kick in the ***
Old May 21, 2006 | 04:17 PM
Cliff's Avatar
I hope you have an after market fuel pump and ARP rod bolts. Good numbers.
Old May 22, 2006 | 07:49 AM
348Beast's Avatar
thanks guys... I can't wait to hit the track friday.. It's gonna be a blast..
