Odd electrical problem raised idel when armed
Old May 23, 2006 | 11:07 AM
98redorangeta's Avatar
Default Odd electrical problem raised idel when armed
Well the problem is really wierd because when you flip the switch to arm the sytem the rpm raises up about 300-400 rpm. The system is grounded threw a window switch so it dosent have a ground when armed but it still rases the rpm when you flip the switch. It goes right back down when you trun it off and right back up again when its turned back on. Any one ever heard of some thing like this?
Old May 23, 2006 | 11:13 AM
Hocky's Avatar
I experienced the exact same thing with my old zex nmu / msd digital window switch combo... rpms would come up almost 1000rpm.
Old May 23, 2006 | 12:16 PM
Brian2006's Avatar
so out of curiosity, how do you solve it?
Old May 23, 2006 | 01:51 PM
Hocky's Avatar
I don't have any idea what the cause was. After I changed to my fjo controller and bigger noids the issue was gone.
Old May 23, 2006 | 04:57 PM
Matt@HSW's Avatar
Chances are it's the way the wires were routed or a stray electrical connection. The coils seem to pick up a lot of interference. Double check the connections and maybe route your wires a little differently.
Matt
Old May 24, 2006 | 04:09 PM
Thanks for the replys guys as long as it dosent mean the system is messed up we are cool.
Old May 24, 2006 | 10:06 PM
70mousjob's Avatar
I had a problem similar to this with my Zeitronix wb02. My window switch gives me no grief, but the zietronix did as you described. When I hooked the scanner up to my car I noticed the TPS was reading about 3% at idle. Hmmmm. Unhooked TPS signal from zeitronix and all was well. Havn't hooked it up since.
Old May 25, 2006 | 10:03 AM
thanks i will check my scanner and see if the tps moves when i flip the switch.
