Rev limiter and window switch
Old May 27, 2006 | 07:16 PM
goodrich969's Avatar
Default Rev limiter and window switch
I have a 96 T/a and im sure the rev limiter is still on it. im curious what pills i should get when i get the window switch.. Im pretty sure its very bad to have nitrous being sprayed when the rev limiter kicks in, isnt it?
Another question... how do i hook up the window switch?
Thanks
Old May 27, 2006 | 09:04 PM
Ramshaft's Avatar
do you have a manual trans?
Old May 28, 2006 | 01:02 AM
nope....
Old May 28, 2006 | 01:53 AM
ZoFastSS's Avatar
Yes, you want the window switch to shut the Nos off at least 3000 before the rev. limiter kicks in.
Old May 28, 2006 | 05:07 AM
DD966's Avatar
Mine is set to shut off 700 before the rev. limiter kicks in.
Old May 28, 2006 | 10:04 AM
DuronClocker's Avatar
I'm assuming he meant 300RPM...otherwise my kit will be spraying from 3000-4000RPMs and that's it
Old May 28, 2006 | 10:11 AM
so does anyone know when the rev limiter kicks in
Old May 28, 2006 | 11:14 AM
Robert56's Avatar
Check the wiring sticky for hook up.
Robert
