Best Piston for Nitrous
Old May 31, 2006 | 02:11 PM
Hooper's Avatar
Default Best Piston for Nitrous
What are the best pistons to buy for nitrous application? I have a h/c car and want to spray a 100 wet shot. I have been advised against it as my stock shortblock won't handle it. Any advice is appreciated.
Old May 31, 2006 | 02:52 PM
Noyzee's Avatar
8 second mod
i have had great luck with dimond.
i run a dimond shelf pistion in B-Mans car with a 125 and no issues knock on wood, she is doing great.
10.4 @ 129 3700 pound car!
Old May 31, 2006 | 02:59 PM
redline2k's Avatar
Stock pistons will work fine for that. If you are intent that you really need them, then I 2nd the Diamond name.
Old May 31, 2006 | 05:29 PM
Matt@HSW's Avatar
Third for the Diamonds, both off the shelf and custom N2O pistons. In all honesty you shouldn't have a problem on the stock bottom end of a H/C car and a 100 shot, as long as the fuel system is up to the task and the tune is good.
Matt
Old May 31, 2006 | 05:51 PM
theblur98ss's Avatar
How much nitrous are the off the shelf diamonds good for? I'm hoping to do a 250 shot(total) 2 stage on them.
Old May 31, 2006 | 06:15 PM
Matt@HSW's Avatar
I want to say they are "good" for a 200 shot. We've and I'm sure countless others have far exceeded that with no issues, but like always your results may vary.
Matt
Old Jun 1, 2006 | 06:48 AM
Noyzee's Avatar
8 second mod
my old pistions where off the shelf but coated, and i wacked them with 300 for a long time!
Old Jun 1, 2006 | 07:19 AM
bowtieman81's Avatar
Matt
This is good to hear. I have been contemplating if it is worth throwing in some forged pistons for a h/c engine with a 100-125 dry shot. Sounds like I will just leave the stock short block alone.
Old Jun 1, 2006 | 07:43 AM
Noyzee's Avatar
8 second mod
usually the stock pistions are ok, its the rings that go bad
Old Jun 1, 2006 | 09:33 AM
At what power level do rings give out?
Old Jun 1, 2006 | 02:14 PM
Noyzee's Avatar
8 second mod
i have seen them go with stock cars all the way to 600-700 rwhp! depends on alot of things, tune, heat, mantinace ect ect
