Should I bump the jets?
Old Jun 3, 2006 | 01:47 PM
boostedrs's Avatar
Default Should I bump the jets?
Right now I'm in a spot trying to see what I should change the jets to or leave them alone. My motor is is an LS1 347 honed to 3.905, blueprinted, and decked a couple thousanths of an inch. The internals are Diamond Forged pistons with thermo coating and 7 cc valve relieves, Eagle H beam forged rods, federal mogul bearings for the internals. The heads are 98 ported heads that have been o-ringed, ported, and have double valve springs. The cam in the car is a Thunder Racing 236/230 .602/.575 112 LSA. I'm about to go get it tuned on a bigger shot (I think) Right now it has jets in it for a little over a 125 rwhp shot. I'm using a NX Dual Nozzle kit atm. I have logged some passes and im not getting any knock even though I'm at 31 degrees of timing. But when I get it tuned on the dyno I'm going to go with a more safe nitrous tune. I'm wanting to get the most possible out of this car. What should I safely bump the jets up to?
Old Jun 3, 2006 | 01:55 PM
krazy4's Avatar
bump em
Old Jun 3, 2006 | 03:17 PM
NoMoreFWD's Avatar
Sounds like you have the right parts to go a little bigger.
Old Jun 3, 2006 | 04:04 PM
01_ram-air's Avatar
You'll be able to run a 150 shot no problem. Go for it.
Old Jun 3, 2006 | 05:47 PM
227Hawk's Avatar
I'm not seeing any mention of fuel system? That needs to be addressed to.
Hawk
Old Jun 3, 2006 | 07:37 PM
NoMoreFWD's Avatar
Good point hawk.
Old Jun 4, 2006 | 09:04 AM
under pressure's Avatar
Are you running this with pump gas and 31 degrees of timing? Just curious.
Old Jun 4, 2006 | 02:06 PM
badass 2002 z28's Avatar
drop the timing, bump the jets
Old Jun 4, 2006 | 05:50 PM
boostedrs's Avatar
Right now the fuel system is stock injectors and a Walboro 340 pump so fuel should be alright?
Old Jun 4, 2006 | 06:41 PM
BROKEN's Avatar
i would prob say get sum injectors just to help out
Old Jun 26, 2006 | 05:52 PM
boostedrs's Avatar
Yes currently that's what I am doing... I'm getting no KR at all though. But am scared to up more then a 125 without pulling timing.
