What else do I need???
Old Jun 6, 2006 | 11:03 PM
exstanger's Avatar
Default What else do I need???
I was wondering what else I would need to install a 100 dry shot on the bird.
I have the bottle, brackets, feed line, n2o solonoid, purge solonoid, wot switch, relays, wiring, and the arm and purge switch.
Thanks. I also have a carb plate but no fuel noid thanks to someone who apparently NEEDED it worse than me.
Old Jun 6, 2006 | 11:08 PM
brad8266's Avatar
colder plugs, fuel pressure switch, and window switch.
Old Jun 6, 2006 | 11:15 PM
exstanger's Avatar
Yeah I meant just to make the kit functional. I might be selling it or I might put it on the car, or both
Old Jun 7, 2006 | 01:54 AM
CAT3's Avatar
Restricted User
How about a nozzle? Nitrous Filter if you want to use it. Carb plate wont do many ppl any good round these parts...
Old Jun 8, 2006 | 11:36 AM
exstanger's Avatar
OK what nozzle do you recomend. Also how long of a line are you using from the solonoid to the nozzle. What's the best place to put the nozzle with the k&n fipk. I assume that I would need the jets too. Anything else I'm missing.
Old Jun 8, 2006 | 12:23 PM
CAT3's Avatar
Restricted User
With my old K&N FIPK, I used a NX Shark Nozzle mounted b/w the MAF and Throttle Body (wet always goes post MAF) screw into the side of a Fernco bellows (3" thick rubber coupler available from Lowes/Home Dept in the plumbing section).
