next racing - nitrous update
I really do wish you good luck. I don't like to hear of anyone destroying their motors which is basically destroying $$$ that I'm sure you worked hard to earn. I do give you major kudos for trying to push the envelope, but sometimes you got to use some sense and you learned that the hard way. I hope you get it back together soon enough and are able to get out there and enjoy racing your car. If you can get that thing to take a 425+ shot without damage I'll be the first on here to congratulate you, not to mention you'll probably hit 8s.
Good Luck.
Now sir to the bulk of your post which are all reasonable statements or legitimate questions.
There are folks that have sprayed that much. That is still not my reason for it. The whole idea is to push the envelope. It's just a part of the way that I race. The lack of sense part comes with being insane enough to hit both kits when they made the killer numbers on one alone. In hindsight, I should have backed it down to test the a/f with both kits together. However, with that said, imagine if it did hold and I was posting on here about the results
Truth is your not in the wrong for thinking it was crazy (or the eloquent use of 'dumbass' as you may). Do I need to be on here posting all of this? Nope, but I'm offering up my experience and there you have it.
The comparison of the motor/spray numbers are with more timing pulled hence the lower motor number (430 something).
Hope that helps.
Good luck with the car - I'm sure it will haul *** when you are done. I have a similar setup to what you are probably going to on the car (plate + fogger)....it seems to be the best choice for what we are doing with the lsx motors.
just to help clarify.this has been done before,and survived many times on a couple of esp's cars.2 of which have gone 8.9xs.Erics car will have no problem taking that kind of hit when it is back together.
This year I am sure there will be at least 3-4 esp cars that will be running in the 8's on that kind of hit.noyzee,nautilas,next,and maybe b man.
there also are some cars down south that run in the 8's that i'm sure are spraying a good amount to run that fast.
Hope that helps.
Ahh, got ya.
i know he is right on, and now with his help, i have learned a lot about tune ups, and know we are right on.
once your good, your good.
as for the 400+ shot, im going to be in that area, pushing the envolope is fun!!
Gary, me, timmy, and next yes, but b-man hasnt even looked at his car yet this year, he sucks
i spent alot of time on that car
so whats the idea/theory behind making it hit softer?
am i correct in assuming that the reason for the "softer" inital hit is to lower the peak cyl pressure when it first kicks on, thereby helping hold the heads down?
are you going to be running a progressive controller now?
and on a non-nitrous topic... are you converting the block to larger headstuds now?
My experience is that plate kits just hit harder than direct ports. Not sure of the science behind it and maybe someone else can chime in and give their thoughts. I'm just telling what I've felt being in the drivers seat.
Yes the idea is to soften to help keep the heads down.
I've been running a progressive controller on the car but for the 2 stage setup I only plan on utilizing the timer aspect of my FJO controller to activate the 2 kit at 100%.
I am already running the larger head studs. I just need GM to supply another stud
HEY ORVILLE, WHY THE **** ARE YOU SPENDING SO MUCH MONEY TRYING TO FLY WHEN IT'S OBVIOUS IT AIN'T GONNA WORK!!! IF GOD WANTED YOU TO FLY HE'D HAVE GIVEN YOU WINGS!!!!!
SINCERELY,
JACK MEOFF
Seriously though I totally understand what next was doing. crazy? yes....could have been done differently? maybe.... But it's people like him that are willing to push the envelope that might someday save other people's motors cause of what he learned. I plan on running a 400 hit on my LT1 that will be terrorizing tracks this fall.. Am I worried? Yup.... Will it be groundbreaking? not really since Taner has done it and several have run 300 shots with no problems for awhile.... But hopefully I can run both kits and provide much needed knowledge to the LT1 community about what it'll take to survive that much power...... I commend you next for what you're trying to do..... And don't be jealous about the LT1's extra head bolt..... we had to have something better somewhere....
Thanks OutlawZ. Good luck with your setup.
But that **** is too expensive!
