What heat range plugs are you guys running...
I have ran 8's for a long time but now i'm running 9's setup is 383 12.1 compression on 93 octain with a low pressure stand alone with 116 nos I'm currently running a 2stage wet 150tnt and a direct port 300
Originally Posted by Matt@HSW
5, running a set of NGK BR7EF.
Matt
Matt
And Phil, setup is 374 stroker, 11.3:1 compression, 200 tnt wet and 100 dry, 93 octane in main tank and been runnin 110 in the standalone (high pressure) since I got it.
Originally Posted by Loudmouth LS1
Hey Matt, what's the diff between the NGK BR7EF and the BP7EFS? I'm running the BP7EFS and was under the assumption they were equivalent to a 7?
The difference between the two plugs is that the BP7EFS is a non-resistor plug. They are however still within the same heat range 7. Here is a breakdown of the NGK part number:
B=14mm thread diameter
P=Projected Insulator Construction
7=heat range (NGK - the higher the # the colder the range)
EF=Tapered Seat .708" reach
S=Standard 2.5mm diameter center electrode
R=Resistor type construction
7=heat range
Nick
Originally Posted by nick@hsw
Devon,
7=heat range
Nick
7=heat range
Nick
EFI = Resistor Style Plug
If you are running a Non Resistor plug you could pick up a lot of interference.
Matt
Matt
Interference as in with your guages, PCM, idle. That kind of stuff.
Matt
Matt
Restricted User
Originally Posted by ATVracr
The ET heads seem to need a way colder plug then AFR or stock ported even on the motor.
Good luck!
Good luck!
Originally Posted by CAT3
I'm not sure about this one. I have been ETP Heads w/ TR6 and seems to be just as it did with stock heads and TR 6 plugs. Same gap, markings on the plugs etc...it may be the difference in Compression, stock 10.1:1 to the now ETP 347 @ 11.47:1?
Low timing and 12:1 AF it still specled the TR6's Wont even get into what we had to run on the jug.
