Fueling Question (nitrous realated)
Ok i have a 255 Holley inline pump that ive run since i got this motor. Will this pump be enough to do a 150 shot wet?? I also have a 155 Walbro booster pump from a Vortech kit that wasnt used. Should i use both pumps just for safty? or will the 255 be fine? I plan on in the next couple months stepin up to 200 shot wet.
Restricted User
255 is the same as the Walbro and I used to run 180 wet pulled off the rail so you should be ok. I would say anymore and you should look into a dedicated fuel cell, gives more flexibility and less worry.
