converting to dual nozzle
Old Jun 25, 2006 | 07:19 PM
faust's Avatar
Default converting to dual nozzle
i have the nx 20920-10 kit that i'm starting to install and would like to change it to a dual nozzle set up. found some nice 3 an y's from harris and another shark nozzle and a mounting fitting, and a couple of hoses from dave and i should be good .right ? or am I over simplifing this and forgetting some thing other than the jets, which would be nice if some one could tell me which jets i'll need for a 100 shot in a dual system with a 385 ci ltx thanks. oh and before someone says did you run a search? I did
Old Jun 25, 2006 | 07:42 PM
LS1x2's Avatar
Formerly 4mulaJoe
You basically just need some fittings and line. Easiest thing would be to call NX and have them give you part #'s.
Old Jun 26, 2006 | 12:07 AM
streetwarrior96's Avatar
I also had mine converted to a dual jet. All I did was just buy the extra lines and the shark nozzle. He put the nozzles on the T/B. Right now I have is setup for 150.... 75/75. This is the design my friend did. I just recently orderd MSD 2 Step and MSD Digital Retard to retard my timing when I spray 200 shot.
Old Jun 26, 2006 | 12:47 AM
94z28L's Avatar
good lookin set up man, thats how i plan on doing mine when i get some, which way do you have the nozzles spraying?
Old Jun 26, 2006 | 01:32 PM
Nitro Dave's Nitrous Outlet's Avatar
All you need to do this is the following part numbers.
16077- Red 1/8x3x3 Y
16078- Blue 1/8x3x3 Y
10024- 2FT blue -3 hose
10025- 2Ft Red -3 hose
90016- Shark Nozzle
15719- 1/8 Nozzle adapter nut
100 shot jets for dual nozzle
35N 20F
Old Jun 26, 2006 | 04:23 PM
faust's Avatar
kwel thanks now i can start getting it ordered as the wife allowes lol
Old Jun 26, 2006 | 06:21 PM
94z28L's Avatar
on a lt1 would it be better to run a dual nozzle versus a single nozzle?
Old Jun 26, 2006 | 06:34 PM
If you have a good nozzle desighn and are not spraying alot (as in 250 pluss I would save my money and put it somewhere else.
Dave
