Stock LS1... have NX kit... Need Advice!
Hey all,
The only mods I have are in the sig.
However, I still have my NX nitrous setup that I never had a chance to install in my LT1.
My first question is, the nitrous setup is pretty much the same as an LT1 I'm assuming right? Just mounting things differently. If not, what would I need should I put it in my LS1?
The next question, Should I put it in my LS1 ? I Have EVERYTHING. I have the accessory kit with the gauge, blowdown, heater, FPSS, etc. I also have some TR6 Plugs and a Window switch with all the pills.
Now, all of this stuff has been sitting for SEVERAL years without use. I partially installed it on my LT1, but never had the time to finish setting it up and actually use it. Is there any problems with this stuff sitting for a long time? The bottle was never filled or anything like that. I'm sure this is a stupid question.
Also, is there a better linkage setup to get? I was looking into the Jimmy Jams or whatever for my LT1, is there anything like that for an LS1? What else should I get to start spraying?
Sorry for all the noob questions. I'm new to the LS1 and nitrous, so I appreciate all the advice you can give me.
Thanks guys!
Thanks guys!
if the kit was never used i would think your parts would still be good.is it a maf kit or the nozzle ? i don't know if there is a difference or not from the ls1 to the lt1 but i would put it on and test it out on a low setting like a 50 shot and go up from there.
