What do you gap your TR6's to?
Old Jul 3, 2006 | 03:07 PM
WS6HUMMER's Avatar
Default What do you gap your TR6's to?
I heard the stock gap setting on an ls1 is .060" and that for every 50 hp over stock to close the gap by .004" So I figured I'd set the gap for an extra 225 hp (with the 125hp pills in) and set the gap @ .042" Is this right? N/A my car makes about 390 rwhp. I just read the sticky about spark plugs and saw that .038" is reccomended for a 125 shot like I plan on running and now I'm really confused! Any insight will be greatly appreciated, if I did this wrong and need to re gap my plug I want to know.
Old Jul 3, 2006 | 03:33 PM
xaon's Avatar
The factory gapping is @ .060", but that is on factory heat range plug. (ie. TR5)
The TR6 plug is 1-step colder and therefore needs a smaller gap. .038" on the TR6 should work very well for your car.
Old Jul 3, 2006 | 03:36 PM
Ramshaft's Avatar
if you look in the spark plug sticky it will tell you what the gap should be for mine it was between .35 to .38
Old Jul 3, 2006 | 03:56 PM
WS6HUMMER's Avatar
Thanks, guess I'll just have to pull and regap all the plugs.
Old Jul 3, 2006 | 04:56 PM
cantdrv65's Avatar
Post
TR6's are gapped right at .035 to .038 when you buy them. That is perfect. I simply check gaps against one another when I install the TR6s....
Old Jul 3, 2006 | 05:48 PM
WS6HUMMER's Avatar
Thanks but I already installed mine gapped @ .042
I'll be pulling them and re-gapping them in a few minutes.
Old Jul 3, 2006 | 05:50 PM
Ramshaft's Avatar
really sorry to hear that. it is bad enough to do it once but twice damn
Old Jul 3, 2006 | 05:53 PM
WS6HUMMER's Avatar
LOL! Yep, my hands are so scratched and bruised. I got the smog line block off plates coming from thunder now too, tired of moving those things out of the way everytime I get ready to acess my plugs or wires.
Old Jul 3, 2006 | 06:02 PM
Ramshaft's Avatar
Well good luck
Old Jul 4, 2006 | 10:54 AM
cantdrv65's Avatar
Post
Youd be fine with the .042 gap actually. No need to split hairs....but whatever you want to do.
Old Jul 4, 2006 | 11:02 AM
CAT3's Avatar
Restricted User
Sticky on plugs is worth it. Rule of Thumb, dont exceed +.005 or -.005 from factory preset gap of the plug, e.g. TR6 is preset at .035", you should be able to stay in .030-.040" range, if not, then you should use a different plug.
Old Jul 4, 2006 | 06:52 PM
red fury's Avatar
.033 here
Old Jul 5, 2006 | 09:01 AM
WS6HUMMER's Avatar
Thanks for all the input everyone. I yanked all of them on the 3rd and reset them to .035 I just dont want a backfire or any detonation.
