Ok nitrous gurus.. i've been thinking
Anywho before we get into my new theory.. lemme tell you guys about the setup..
basically heres what i got.. Two enitrely independent NX wet kits.. complete with there own bottle's.. feeds.. each being used in a standard wet configuration with the nozzle in the bellows.. Both fed from a standalone fuel system.. for nitrous only..
now heres where things change.. with the flow through NX solenoids.. i have a -4 line coming out of where the purge solenoid would be mounted on both kits.. these Y together and into another Flow through NX noid wich feeds the dual nozzle dry kit.. and then a single purge.. SO.. while both kits are independent.. they are common..and all have a single feed.. so while it would be inefficient as all hell.. one bottle could feed all 3 kits.. i have also built my own sort of controller box using 2 FJO units and 2 window switches.. to control the 3 kits from the passenger compartment..
Now heres the question.. I am a pump gas guy.. I give my car a 200hit on 93 octane on a regualar basis.. but i have yet to play with the dry other than on the dyno.. where yes it works fine.. a/f is safe blah blah.. but i'm a firm beleiver you can never be TOO safe..
now heres the theory.. i want to use some sort of water meth IN ADDITION TO.. my already safe tune.. now we are not talking about a large quantity here.. just a fine mist of the stuff to kind of cool and prevent detonation sprayed in also in the bellows just before the wet nozzles.. now i know everyones gunna say "just put race gas in it" and now that i said that some smart *** about 4 posts down is gunna say it.. BUT.. do you guys see any reason I can't pull this off?? with the combination of kits and controllers i can run anywhere between 75 an 525 HP worth of nitrous at the flip of a switch should i so feel the need.. and i need everything i can get to help out..
After all this is still a STOCK bottom end
Mike
I don't see why it wouldn't work. I now nitrous has a good cooling effect and u have a safe tune but I'm with u, u can never be too safe. Sorry I cann't give u ur answer because I haven't messed with meth injection with nitrous but I know of several guys around here using them with thier S/C or turbo setup from 4cyl to 10cyl and they love them.
I will be keeping track of this thread
Cat.. it has nothing to do with breaking ground it has simply to do with the octane of the meth and the egt cooling effect that water has.. however.. i never really thought about the freezing factor..
how ever according to this chart at 75% meth 25%water the freezing point would be -215*.. i think that would be plenty..
ok so lets say it doesn;t work.. whats the worst its gunna do?? you think it will blow the motor?? remember i'm talking about misting through 2 .006 orfices..
Mike
PS. of course i want that extra increase in torque..
I think my head is smoking..
Mike
BTW didnt mean you were trying to be a pathfinder on this one, with the groundbreaking, just get the goosebumps thinking of trying new things and its always hard to support someone stepping into the undiscovered, from a guilt ridden personality sort of way.
Charlie
Charlie
No sweat.. like i said this is just me thinking.. and its gunna involve me getting off my fat *** to actually finish it.. which could be awhile.. cuz i'm lazy.. just wondering if anyone was doing this..
I thought about propane.. but for me thats too many variables.. gottta have a heater on the propane tand.. and nitrous bottle.. bleh.. i dunno just me..
Mike
Robert
