OK im stupid. FJO help
I am having trouble with my FJO mini controller. i cannot get it to spray from a roll?? how is the window switch set, i have 1st gear lock out. So how does it know or see 1st gear. Or is it just looking for the 1st rpm sweep and then arms it self and spray.
The first gear lockout feature prevents the solenoids from firing until the controller sees the RPM hit your upper threshold of your window. Each time the unit is powered on, it will assume you are starting in 1st gear.
If you want the unit to only block 1st gear but fire if you are starting in a rolling start, use the trigger input. Connect it to a micro switch that is ON when you are in 1st gear (manual transmission only). Set the config so the stage is disabled when the switch is on.
Hope that helps.
Hope that helps.
