Arm System and Shift Light Goes Off??
Old Jul 18, 2006 | 05:35 PM
Johnny5's Avatar
Default Arm System and Shift Light Goes Off??
Tapped into the same 12v power wire for both the shift light and the arming switch. When I turn on the system the shift light goes out. Is that really too much draw to have a shift light with a few LED's and the arming unit. All my switches control relays so it is all really low voltage.
Anyone have any ideas? Could it be because they are also grounded in the same spot?
Old Jul 18, 2006 | 07:34 PM
Brian2006's Avatar
Too much power to one power source. Tap into somewhere else
Old Jul 18, 2006 | 08:59 PM
Johnny5's Avatar
If I used the TCS wire to trigger a relay would that do it instead of just using the wire itself?
