Few things
So question is, what would be a safe shot to use? It's my first time using spray and I don't want to start too aggressive. I know all about the kit and the WOT, the better spark plugs, etc and to spray at WOT, so just for semantics, I hit WOT, spray, let off spray to shift, wait til WOT in the next gear and spray again? Eh, sorry for the newbie questions, but I also don't know anyone from experience who has ran nitrous.
Lastly, does anyone know a legitimately good speed shop in the NJ/NY/PA/CT area? I want to take my car to a place that has a lot of experience with LS1s/nitrous/etc. Thanks for the answers ahead of time.
-Andrew
Take a look at Matt's site, he is a Sponsor, look for the HSW logo.
Give him a call or shoot him a PM.
Edit: Noticed it was your first post
Welcome to the Board
Anyway, could you possibly answer those other questions I asked? I've seen you posting around here so you must be pretty knowledgable.
But I have read, researched, and talked with most all the vendors while putting my kit together, in addition I stayed in a Holiday Inn Select for crew change a few times
Plugs, Correct need colder plugs, Matt was nice enough to make the sticky at the top for what plugs to get, so when he made up my hoses I bought my plugs from him too.
In addition to a base kit (wet or dry your pick), you should get a bottle heater (cus your a yankee like me) and you need to heat the bottle up to maintain the pressure around 950 PSI, and a window switch so the juice only shoots at 3000 to whatever you want.
Read the stickies at the top on the wet or dry question, talk to Matt and or the other vendors on the issue.
Likely your looking at a 100-125 Dry for your needs or a 100-150 wet.
Welcome to LS1tech. The best way to gain reading knowledge is to search the nitrous section and read what you can. The key to using nitrous safely is knowledge. Make sure you use a window switch also. If I can help you in anyway let me know.
Dave
Let us know what we can do to help ya!
