Empty bottle..low TQ??
Old Jul 21, 2006 | 11:39 PM
99FormulaWs6's Avatar
Default Empty bottle..low TQ??
After my nitrous install, we dynoed the car, and we didn't have a full bottle, so we used a near empty bottle, and I'm thinking my tq numbers are down quite a bit. This is a GTP St.2 heads, TR224 cam, and an NOS Wet plate kit, with an NOS progressive controller, and no bottle preasure.
542HP/542TQ
Here's the numbers:
Carl Owens: 90.88 °F 29.52 in-Hg Humidity: 55 % SAE: 1.04
--s----RPM x-1000-----ft-lbs--Air/Fuel
1.03--3.20--197.59--324.45--14.38
1.18--3.30--215.92--343.43--14.27
1.26--3.40--268.75--414.28--14.20
1.34--3.50--318.41--477.55--14.23
1.43--3.60--342.23--499.31--14.44
1.51--3.70--357.20--506.92--14.66
1.62--3.80--369.00--510.06--14.41
1.72--3.90--377.20--507.95--13.94
1.81--4.00--393.13--516.12--13.54
1.90--4.10--406.79--521.12--13.16
1.98--4.20--421.14--526.56--12.92
2.06--4.30--438.58--535.61--12.77
2.16--4.40--447.13--533.79--12.70
2.27--4.50--455.02--531.03--12.69
2.35--4.60--471.18--537.94--12.70
2.44--4.70--484.92--541.88--12.73
2.54--4.80--495.39--542.06--12.78
2.65--4.90--501.72--537.80--12.84
2.78--5.00--495.72--520.75--12.88
2.91--5.10--494.13--508.88--12.86
3.01--5.20--504.58--509.62--12.78
3.12--5.30--516.50--511.83--12.71
3.24--5.40--517.03--502.91--12.71
3.36--5.50--511.00--487.98--12.77
3.48--5.60--518.00--485.82--12.80
3.59--5.70--526.62--485.24--12.84
3.71--5.80--536.41--485.74--12.89
3.82--5.90--539.96--480.68--12.96
3.95--6.00--542.11--474.56--|13.01
4.07--6.10--541.20--465.98--13.09
4.20--6.20--537.77--455.56--13.16
4.34--6.30--534.58--445.72--13.17
4.47--6.40--523.84--429.95--13.20
MAX:--4.47--6.40----542.11--542.06--14.66
MIN:--1.03--3.20-----197.59--324.45--12.69
Old Jul 22, 2006 | 12:39 AM
CraZee ZO6's Avatar
Low bottle pressure will cause a drop in TQE and HP.
Spray at 1000-1100psi.
Old Jul 22, 2006 | 01:09 AM
So roughly how much are we missing?
Old Jul 22, 2006 | 01:33 AM
slowpoke96z28's Avatar
WHY spray with an empty bottle? even still, the curve seems to follow the stock one except at the beginning of the nitrous hit, which isn't a surprise considering next to no bottle pressure.
Old Jul 22, 2006 | 02:16 AM
CAT3's Avatar
Restricted User
Might want to get your AFR under control as well. That will make the torque = crap, not enough fuel in there to build the power.
Old Jul 22, 2006 | 09:23 AM
Robert56's Avatar
IIRC, NOS uses a bottle pressure of 950psi when calculating their jet sizing. Higher pressure may mean a little more power/torque but watch your a/f for going to lean.
Robert
Old Jul 22, 2006 | 01:22 PM
We didn't plan to, I just didn't get a chance to fill a bottle before the car was finished, and the fill shop was already closed. When I go back with a full bottle, we'll be tweaking the AFR.
Old Jul 22, 2006 | 09:21 PM
SmaknaSS's Avatar
Dont take this the wrong way but I would be glad to have low bottle pressure during that run because It looks like you are running scary lean.
Old Jul 23, 2006 | 12:01 AM
red91z's Avatar
LS1TECH Sponsor
It's actually not near as lean as it looks. The air fuel gets to around 12.5 in the mid rpm and then ramps up to about 13.1. We'll be putting some fuel in it once we get a full bottle.
