Problems after nitrous instal
Old Jul 24, 2006 | 10:34 PM
speed_demon24's Avatar
Default Problems after nitrous instal
Well I went out to test my nitrous tonight to make sure everything works right, the purge works, heater works, but the nitrous itself is messed up. I went full throttle and turned on the nitrous at 3500 and all the sudden it fell on its face at 4500 RPM's. I have a 100 nitrous jet in and 125 fuel jet in to be safe until I get it on the dyno, but I don't think this would cause that since it pulls hard until 4500 RPM's.
Old Jul 24, 2006 | 10:36 PM
Z284U2TRY's Avatar
did you check and make sure both noids are fireing?
Old Jul 25, 2006 | 08:21 AM
sprayjunkie's Avatar
Definitely a stuck N2O noid!
Old Jul 25, 2006 | 08:23 AM
227Hawk's Avatar
Sounds like the N2O solenoid isn't opening.
Hawk
Old Jul 25, 2006 | 08:25 AM
Bluewire's Avatar
Are you running a fuel pressure saftey switch?
Old Jul 25, 2006 | 08:44 AM
Armyman2445's Avatar
either a noid is stuck or if your running a fuel pressure switch, the pressure switch might be adjusted wrong
Old Jul 25, 2006 | 11:51 AM
I don't have a fp saftey switch, and the nitrous definatly turns on at 3K, but then it nose dives at 4500RPM's. My only guess is it's running too rich with the 125 fuel jet in there.
Old Jul 25, 2006 | 12:17 PM
11SECDWS6's Avatar
You might be getting some predetonation.
Try some race gas and see what happens.
Old Jul 25, 2006 | 12:33 PM
flash12t's Avatar
what window switch do u have. .??
Old Jul 25, 2006 | 12:38 PM
I have the BNM window switch. The only wire on it that I didn't hook up is the wire taht goes to the brake pedal ground. Is there any purpose to that wire? And I'm getting some knock retard on the scanmaster, when I arm it and go WOT it gets 3 degrees every time, when I got WOT then arm it sometimes it gets 0 then other times its like 1/2 degree.
Old Jul 26, 2006 | 09:49 PM
Just to update the thread, I bypassed the window switch and now it works fine.
