Thinking about Nitrious need some help
Old Jul 25, 2006 | 03:26 PM
SRpwred240's Avatar
Default Thinking about Nitrious need some help
I have been planning on doing a cam and stall with a tune in a month or so, and Im thinking about going ahead and putting a ZEX 125shot kit on. Zex claims to have a safe product. I dont go to the track often so Id go once or twice just to get my times and the rest of the time I dont really see me spraying much on the street. Is there anything thats a must change out on a car thats not gonna spray more than a few times here and there or can I just install it tune and and run it.
Old Jul 25, 2006 | 05:57 PM
Matt@HSW's Avatar
Spark plugs, NGK TR6s are pretty popular.
Matt
Old Jul 26, 2006 | 04:08 PM
SRpwred240's Avatar
So should the Stock fuel injectors and fuel pump be good enough and are NGK tr55s good enough spark to handle the 125 spray every once in a while?
Old Jul 26, 2006 | 05:15 PM
Matt@HSW's Avatar
If you do a cam I would suggest doing a fuel pump, like the racetronix kit. If you go with a dry kit you may need to do fuel injectors too. I would not suggest spraying on the TR55 plugs.
Matt
Old Jul 26, 2006 | 07:02 PM
sprydncamd ta's Avatar
any kit is safe as long as its setup correctly and i wouldnt spray on tr55's your not losing anything going to tr6's
Old Jul 26, 2006 | 09:25 PM
SRpwred240's Avatar
How are the tr6s when not spraying are they just as good as the tr55s.
Old Jul 27, 2006 | 04:51 PM
Matt@HSW's Avatar
Your idel will be a little more rough and you may have to change them out a little sooner then the TR55s.
Matt
Old Jul 27, 2006 | 05:06 PM
mudflap1989's Avatar
I's be prepared to put a transmission in also.
Old Jul 29, 2006 | 12:49 AM
terry s's Avatar
If he is running an automatic just set the window switch to shut the nitrous off a few hundred rpm before the transmission shifts so you won't be shifting with the extra torque.
