Possibly a leak???
Old Jul 31, 2006 | 11:52 AM
FireBreathingChicken's Avatar
Default Possibly a leak???
At the end of last summer when I had my bottle filled, i think there was a leak. There was a slight hissing sound coming from the part where you fill the bottle. Well when the car was in the garage for the winter, there was still N20 left in the bottle. By spring time it was completely empty. It's pretty obvious that there may be a leak. How much does it cost to fix? Thanks
Old Jul 31, 2006 | 02:35 PM
CAT3's Avatar
Restricted User
Nothing but about 5 minutes. Turn the valve off, disconnect the feed line from the bottle, remove bottle from brakcets, lift bottle out of car, sit upright on ground. Use large adjustable wrench, tighten the valve to the bottle, and then bottle nut to the valve. Take to a fill station and tell them the bottle needs to be vacuum first since it has been open/dry, then have it filled.
Charlie
Old Aug 1, 2006 | 08:05 AM
Thanks a lot for the info.
