So close to finally hitting the 200 shot(~700rwhp)...
Last year we had our hands full with the 346 and 150 shot. This year we built an even faster 346 but with a 200 direct port. Tonight I finally got time to finish up the wiring and did the inital checks. Everything was set, computers were working fine, gear counter working correctly. I go to open the nitrous bottle and see a big plume of nitrous out of the hood. Check the solenoid and they are closed and working fine, check the solenoid to main feed connection and thats tight. Turns out the main feed line has a pinsized hole about 8 inches from the end.
Restricted User
Yep, thats the kind of stuff that made me stock a ton of spare lines, main feed and noid to jet lines. Always had someone needing them on demand. I never messed one up personally.
Phil. Yesterday I was just thinking to myself that I had not seen you on here in a while. Then pooof there you are.lol
If you still have enough hose you should be able to take it buy a hydrolic hose place and have them put a new end on it. If not and you need a custom lenght we cvan make you one what ever lenght you need.
Dave
Dave
We've been soo busy with new clients its unreal. I just got back from my friends shop where we put together a new hose and its getting installed in a few minutes.
My car is going to be ready to run tonight and friday. We're shooting for 115-120mph in the 1/8 and a good 60'.
