Switch question
Accessory- to your purge noid, the other wire on the noid goes to ground
Ground- needed only to light up the LED on your rocker
Power----switched 12 Volt
Most Purge switches are momentary push buttons, they are $3 at radio shack. The rocker will work, but be carefull not to leave it on, you will waste alot of Nitrous.
