No people know
Old Aug 15, 2006 | 10:44 AM
1BAD01TA's Avatar
Default No people know
I have a nos dry system that started out life as a duel jet well now its well hidden so I only run a single jet. what jet do I need for a 100 shot i have 65 in it now but it hits way too hard, and I think its alot more. THANKS
Old Aug 15, 2006 | 12:45 PM
Somebody09's Avatar
I use a 52 for NX. I think for NOS, you want something like a 1 or 2 jet for a 100 shot. They rate everything weak like little girls.
Old Aug 15, 2006 | 01:17 PM
srsnow's Avatar
It doesn't really matter where the horse power is rated at RWHP or FWHP the jets still flow the same it just depends on if you want 100hp at the wheels or at the flywheel. Rating things at the rear wheels can get a little tricky because of differing amounts of parasitic loss associated with different drivetrain layouts, which is one reason NOS tended to shy away from RWHP ratings but more than anything when a lot of the NOS kits were originally designed chassis dynos weren't as readily available. Now back to your question a 47 jet should get you around 100FWHP and a 5s should get you about 100RWHP.
You can figure out what 2 jets are equal to in a single jet with the following equation;
jet*jet*# of jets = x then the square root of x equals what the same square area of the 2 jets in one
Example: 32*32 = 1024 * 2 = 2048 square root = 45.25
So 1 45 jet is equal to two 32's
The opposite would be;
45*45 / 2 = 1012.5 square root equals 31.8
Old Aug 15, 2006 | 02:01 PM
fstphx's Avatar
Yea i would definatley drop that jet- thats way huge for a basic dry kit- where did you even get one that big- at that point you are almost more limited by your noids than your jet... I run a 52(about 100) - 56(about 150) is as big as i have been willing to push it. there is a good chart somewhere in the sticky-
Old Aug 17, 2006 | 11:02 PM
1BAD01TA's Avatar
yes my 65 is way too big. I used a bad site calculator and the guy at the speed shop didnt know what he was doing. thanks fot the imput,
p.s what would my 65 be about for hp(It hits reallllllllllll hard)
Old Aug 18, 2006 | 09:48 AM
FinalTA's Avatar
I'd say that 65 jet on the NOS 5177 kit is pretty much open hose....meaning it is flowing as much as the noids will let it.
Old Aug 18, 2006 | 09:58 AM
BobbyWS6's Avatar
I put a 65 in mine years ago for one night...I kicked everybodys a$$. I am not sure but I think 65 is a 150shot. But as FinalTA said you are at the limit of the noid. But it sure feels good at the top end!
Old Aug 18, 2006 | 11:47 AM
srsnow's Avatar
It should be 150hp, but it isn't quite at the solenoids limit the solenoid is a .73 orifice
Old Aug 18, 2006 | 04:01 PM
bottlefed01z28's Avatar
why not just get an fjo contoller and hide that and let the hit come in soft and progress it up?
Old Aug 19, 2006 | 07:19 PM
ChevPower's Avatar
a .065 should put around 150-165 to the wheels
Old Aug 19, 2006 | 10:15 PM
CAT3's Avatar
Restricted User
I have yet to see a NOS 5177 run 150rwhp period. I used open lines, no jets and only pulled 115rwhp. Anyway, in the stickies up top there is jet chart, includes single and dual jet sizing.
