Timing on 100 shot ?
Old Aug 15, 2006 | 01:55 PM
kazfan30's Avatar
Default Timing on 100 shot ?
Had car tuned a few weeks ago with mods in sig. Timing ended up at 27* total with no Knock Retard. Im thinkin of trying a 100 shot this fall and dont have a timing tuner yet, just a trick window switch. You guys think i can get away with that small of a shot or wait to get something to retard with??? Thanks as always
Old Aug 15, 2006 | 11:15 PM
charlie c5's Avatar
Absolutly. you will do fine. But, keep in mind that anything too much bigger and I'd have your tune checked, and maybe have some timing pulled.
Old Aug 16, 2006 | 12:30 AM
nitroushane's Avatar
What is the best way to pull the timing out? Is there any way to do this at the track? I have an auto tap program to check for knock. Is there anything on the market for timing adjustment that u can run with a laptop and doesnt cost an arm and a leg? I have a 125hp shot and have no problems with timing at what hp level do u have to start pulling out timing and how much do u need to pull out. I'm planing to up the nitrous to 150 shot, just wanted to do some research first. Better to be safe than sorry. An help would be great.
Old Aug 16, 2006 | 09:00 AM
Matt@HSW's Avatar
Any of the tuning programs (Edit, HP tuners) can do what you are looking for. If you want a stand alone device take a look at the LS1 Timing Tuner:
http://www.harrisspeedworks.com/shop...cat=308&page=1
It will allow you to run full timing NA and pull some when you spray.
Matt
Old Aug 22, 2006 | 01:41 AM
thanks for the help
Old Sep 3, 2006 | 10:25 AM
HD1911's Avatar
Matt
Hey, will the Timing Tuner do the opposite of what you just stated??? as in if my timing on my tune right now is at 22 degrees because i spray a 200 shot. But when i am tooling around town n/a on a stock motor w/bolt ons, the car feels neutered as hell and is significantly slower. I want to be able to put timing back into the car but then when i spray, it be pulled back enough for a 200 shot. problem is it is a mail order tune setup completely for when i am spraying that 200.
