Dry system questions - PLEASE HELP
I am going with either #37 or #42's (same price at HSW) right now I am leaning towards 37# Delphi injectors, there seems to be an even split when I ask SVO or Delphi from various sponsors and EFI Live users.
Beer
i would browse through hsw's site they have high quality kits and are very helpful
Don't forget to check out the PRO Dry kit. Something that's more common now is the swelling plunger issue on the wet hits. We must keep on top of this. I think your fine on your fuel system and your hp level. Start at 100 and check for duty cycle, a/f and kr and you'll be fine. Smart choice going dry. Watch for a new dry kit from Nitrous Direct (Ultimate PRO Dry), it's in testing right now and is working flawlessly.
Robert
If go with wet, your racetronix pump would have you covered and no need to swap injectors. All you would need to buy is the wet kit and put it on the dyno and check the A/F so you can sleep at night.
If you will run a window switch and set it at no less than 3000rpm should never have to worry about a backfire with a wet kit.
Also, one thing to remember, the 80% duty cycle rule is for longevity. If you are going past 80% on a 1/4 run don't be to concerned as you really aren't putting much additional wear onto injectors. just stay away from going static as this can cause over heating issues and failure, but some still go past 100%.
550bhp x .5 = 275
275 / 6.4 = 42.96lb inj So, your fine as you allready have 42lb'ers (37svo's). Actually you can even go further in the future and still be fine.
Robert
