WOT switch questions
ok well i was hooking up everything today and got most of it done but in the process of figuring out where to mount my mechanical WOT switch and bending the bracket a bigillion times I broke the switch. Would a electrical switch be more reliable then a mechanical seeing as i cant seem to fit in on the throttle body or the pedel? What is the voltage range for our TPS? 0-5v? anyone recommend a unit for me? i have a window switch as well Thanks
IIRC Dynotune has a multi swithc, built in WS and TPS. You can bend that little arm to fit on the Throttle cable bracket bolt; as viewed from the front, it be mounted to the bolthole, bending towards the pass side of the car, then bending down to where with the WOT mounted it would contact the throttle blade cam arm. There should be pics of you try the search button.
ya iv seen the pics of the switches on the throttle bodies and the pedals using the search button but i cant get the thing to fit. I have a BBK throttle body so it is extended a lil bit further out with the bracket. Either the cable is in the way or the PCV tube off the throttle body gets in the way. Since i have the BBK it sticks out further from throttle body
