Is it safe to...
Old Aug 18, 2006 | 03:07 PM
WIPLSH's Avatar
Default Is it safe to...
Is it safe to spray 100 wet on the LS6 intake manifold?
i was wondering due to the risk of a backfire
Thanks
chris
Old Aug 18, 2006 | 03:10 PM
spare tire's Avatar
I dont understand why it would hurt? Did you use the ls1 coolant pipes or the ls6?
Old Aug 18, 2006 | 03:47 PM
Reject's Avatar
spraying threw the stock ls6 intake manifold? that's the question right? if so yeah safe, just make sure you have all of your saftey items on like the wot switch and a window switch....and dont over see the spark plugs, do the sparkplugs before you forget about them!! hope that was your question.
Old Aug 18, 2006 | 04:18 PM
Ed Blown Vert's Avatar
Its safe if you use all the safety devices. (Window Switch)
I have been spraying for many years.
Old Aug 18, 2006 | 04:30 PM
Robert56's Avatar
Intake explosions are a minimal risk. Dosen't happen to much. Mostly from user error or install error.
Robert
Old Aug 18, 2006 | 05:26 PM
WIPLSH's Avatar
ok thanks guys
this is gonna be the first car ive every put spray on, never had a plastic intake manifold either lol.
what rpm should the window be set at? 3100-? 6000
Old Aug 18, 2006 | 05:30 PM
Reject's Avatar
have you read the sticky up top? heres a link for quick action https://ls1tech.com/forums/removed-locked-thread-graveyard/458352-nitrous-faq-s-nitrous-push-systems-merged.html
Old Aug 18, 2006 | 07:14 PM
SSDoubleK's Avatar
Never activate the Nitrous, below 2500, detonation has alot bigger chance to happen below that rpm. I have my Zex Traction Control Window Switch to kick on at 2700 and kick out at 6000rpms, I have first gear locked out, thats a nice feature with this switch. When I go to the track the rpms kick on at 2600 and off at 6200rpms, I have a cam so I'm able to take the revs up a little higher. Hope this helps.
Old Aug 19, 2006 | 03:44 PM
WIPLSH's Avatar
OK thanks guys,
thanks for the info
