Dynotune 2 stage controller ??
Old Aug 19, 2006 | 09:18 AM
Firechikn's Avatar
Default Dynotune 2 stage controller ??
I'm finishing installation of the controller, question is. The white wire is power but, should it be constant non switched, on with key, or on with arming switch. The instructions are not very clear. Does it loose its set points if power is lost ? Thanks.
Old Aug 19, 2006 | 09:33 AM
Mike 02T/A's Avatar
It should get power once you flip the switch. The settings will be saved inside the controller.
Old Aug 19, 2006 | 10:18 AM
Robert56's Avatar
I like the idea of a ign sw source, otherwise if you forget to turn arm sw off you'll continue to have power once the key is off.
Robert
Old Aug 19, 2006 | 10:46 AM
860 Performance's Avatar
I usually hook them up to the arming switch, because if you use a gear lock-out feature. It resets when you flip the switch, otherwise you need to turn the car on /off to reset it.
Its really just preference though either would work.
Vinny
Old Aug 19, 2006 | 01:27 PM
Firechikn's Avatar
Thanks for the info. Good news. After 10 hours of wiring, I didn't want to go back and rewire it. I have it powered by the arm switch now.
Old Aug 20, 2006 | 09:40 AM
Mike 02T/A's Avatar
Robert
That's the way I wired mine up. There's a vacant IGN in the fuse panel by the driver door. It should be in the 1st row of fuses. Put a connector on it and you're all set.
