Dry Tuning guys please look
Chart is 3000 RPM Start through 3000 RPM end (yes I learned how to filter today...
Showing the ranges of each PID through the filter.
Here is my question, during the highlighted part above the Injector DC was over 100%, what makes the DC exceed 100% (am I logging the cause?)? I understand the MAF see's more O2 and commands the injectors to add more fuel. But I am trying so see the corrolation in the graph...
Also I don't really under stand why the 106% is not in the initial hit of nitrous or in the upper RPM's, and why it is in the middle of the nitrous run?
Able to do the PIDs, Chart and Scale, Filter, make new dashes.
Have not dove into the tables yet. Looking like thats next!
That PE tables makes sense though
I'll head off in that direction and read up some more. Robert
4822-5400 is where they are maxed out, DC goes to about 91% through 59XX
The 75 is ugly...
Looks like I need the Tuning software next (only have Scan) and then swap out injectors...42 lb matched injectors what I need?
Looked into PE but I don't think EFIScan will let me look at the table, guessing I need EFITune to get into that. Got a little confused on VE and PE, but I think I understand the diff now.
Based on maxing out @ 50 Dry with the 26 lb injectors, I can see why Wet is the way to go, at least for us poor bastards stuck with the stock 26's anyway. Damn glad I got Dave's Plate for a Wet Shot.
Matt
Well you can think of the poor bastards this way. The cost of a dry and the injectors together equals or is less than the plate kit. You'ed never have to worry about the swollen plunger issue, the intake hood removal, burning a hole in your piston when the fuel noid sticks shut and a miriad of other scenerios. I had a n2o noid acting up last night at the track. Worked, didn't work, sputtered then finally froze shut. No problems no issues in the damage department. However, I may not have been able to say that with a wet hit and the bog launch that would have resulted.
Robert
(I read the 37's give ya 43 at @58)...Need the Tune software first. PM me here or at your site I was wondering about flow matched 37's. The Best V8 Stories One Small Block at Time
Matt
Robert
