Ordered TNT kit.
Old Aug 19, 2006 | 10:58 PM
BuBbABFP's Avatar
Default Ordered TNT kit.
Hello guys u just ordered te folowing
TNT F1 Kit
DynoTune Two Stage RPM Window/TPS Switch
Fuel Pressure Safety Switch With Chrome Fitting
I know i need tr6 plugs, and im going with a 150 shot btw my buddy is going to give me some 28lb injectors if that helps cause i have a 99 and i heard they are like 26lb or something like that. what else is needed? thx
BuBbA
Old Aug 19, 2006 | 11:13 PM
1QWIKZ's Avatar
fuel pump would be nice.
Old Aug 20, 2006 | 10:34 AM
Bad N Black's Avatar
The F1 is a wet kit. You souldn't need the injectors. Fuel pump would be the best thing to do. You might want to get a bottle heater.
Old Aug 20, 2006 | 04:43 PM
BuBbABFP's Avatar
What fuel pump do you guys recommend? btw will my engine blow if i dont upgrade the fuel pump?
Thx guys, BuBbA.
Old Aug 20, 2006 | 10:43 PM
BLAKE 01 WS6's Avatar
it could lean it out, and that= . on a tnt 150 you will be at 500rwhp, that is around (or maybe a little over) the limit of the stock pump. any 255lhp pump will be fine. racetronix kit is the best(comes with booster wires and everything), i have a holly, walbro is another one. i would do it to be on the safe side. plus its a must if you ever add a cam/heads/cubes. just keep it "fat" and happy
Old Aug 20, 2006 | 11:50 PM
Built LT1's Avatar
Basically what he says. I ran a 240 liter per hour in tank pump with a 383 LT1 and 159 shot of TNT.
